How many hooks do you have?
Re: How many hooks do you have?
I have a total of 12, 4 on top and 8 on the bottom. I have used 8 so far. Just found out my braces should be coming off in June - YEA - That will be a total of 17 months.
kellyb wrote:i only have my lower braces fitted at the moment (uppers to be fitted next month). currently have 2 hooks on lower arch.
as my upper arch is now fitted, i have 4 hooks total
I have 14 hooks...6 on top and 8 on bottom. They have not been used yet, but I am only 12 weeks into my treatment.
I have 8 on cheeks side + 4 on tonge side (with 2 of them "flattened" until they will be used).
It's interesting on how so many of us metal mouths have different number of hooks. I have my first adjustment appointment on Wednesday, so I shall see if I get to wear my elastics on different hooks, or if I'm still stuck on the 6 I'm using now.
I only have four. My orthodontist doesn't know yet if I will need elastics or not.
![Image](http://tickers.TickerFactory.com/ezt/d/4;10722;473/st/20120306/e/I+got+braces%21/dt/17/k/ee3a/event.png)
18 total. I have 8 upper (which are all In-Ovation C brackets with built in "hooks") and 10 on the lower (In-Ovation R with traditional hooks); basically cuspids all the way back. My 2nd upper molar on on each side are not braced.
Just too update: I still have the same configuration, but it will likely change at my next appointment in May to a new configurtion.
I hate elastics!
![BangHead :-+](./images/smilies/BangHead.gif)
The same as me. I might not need themSita wrote:I only have four. My orthodontist doesn't know yet if I will need elastics or not.
![Dance :dance:](./images/smilies/eusa_dance.gif)
![Image](http://tickers.TickerFactory.com/ezt/d/4;10757;450/st/20120120/e/I+got+braces/dt/6/k/70ef/event.png)
![Image](http://tickers.TickerFactory.com/ezt/d/4;10722;117/st/20120903/e/lower+braces/dt/7/k/e637/event.png)
I have 6 on top and 6 on the bottom, praying hard they are only for decoration purposes.
Wishful thinking i think.
Orthodontics translates to tourch-odontics
lolHuggypillow wrote:I have 6 on top and 6 on the bottom, praying hard they are only for decoration purposes.
![SmilenRoll :-*](./images/smilies/toothy12.gif)
i am hoping when i do get elastics (don't think i can avoid them), they will be for night time only
