Who applied your braces?
- BracesChick
Re: Who applied your braces?
Maybe it has to do with how the brackets are put on? A mold of my teeth were made so the ortho could make trays with the brackets that just slide on to my teeth. 4 parts were made. So they didn't have to place each bracket individually.
My orthodontist did mostly everything. His assisstant only handed him whatever he needed at the time.
My dentist is doing my braces (my cases is not complicated) and so far she has done everything - applied the brackets, placed the wire, done the cleanings, etc. The assitant just hands her everything. I'm only 2 months in so I don't know if this will change or not.
- MrsCharisma
Assistant placed the brackets, ortho checked, had her correct a couple (THAT was fun - not!). Then he checked again. THen she cured, then he checked. Then he placed the wire.
Female, 34
Sentence: 18-24 months
Ceramic uppers, metal lowers
Assistant cleaned. Ortho applied. Assistant did the ligatures.
- BraceFace2o1o
My orthodontist applied my braces.
At all adjustments it is my ortho that does the work.
I have Damon braces:
The assistant took impressions, cleaned & prepped my teeth; the ortho placed the brackets as the assistant passed them to him. He also cured the glue with the blue light. I was surprised that she put the wire + coil on, but he did come by to see how she was doing, and then he also did the final inspection before I was sent on my way.
Braced: 11 Feb 2013
Debraced: 13 Aug 2014
Expected duration: 24 months
Actual duration: 18 months
Damon Clear uppers (all); Damon metal lowers
http://fullmetalpanda.wordpress.com/
I am new here-but I had the assistant prep me and the ortho actually put the brackets on. The assistant then put the bands and wire on. I was surprised the assistant did a lot of the work.
I got my braces 4 days ago. The assistant did most of the application (was a bit surprised although it is an incredibly busy office.) The doctor bounced in a number of times to check, give instructions, and apply brackets to my multiple crowns.
My ortho does everything. The assistant does what her role says, assists. She hands him the tools required but that's all. She hasn't come anywhere near my mouth and I don't expect she ever will.
The practice my ortho works at is small. He shares it with his partner but they don't work on the same day so he has time to see each patient completely.
Heather. Wife, mother and 30yr old with braces
Sentenced to 18 months (approx May 2014)
Orthodontist. The therapist did all of the prep work but the application of glue and brackets was all done by the ortho.
Ortho fellow with attending ortho for supervision at beginning of every visit. Then the fellow does everything.
