What type of floss do you use?
FlyByNight
Re: What type of floss do you use?
#16 Post by FlyByNight »
Oral B superfloss that my dentist gave to me when I went for a cleaning. That stuff is great. One firm end to thread it through the brackets.
Mandywill70
#17 Post by Mandywill70 »
Thanks!
I just worked out I have been doing it wrong. I was trying to thread it through the space between my teeth instead up up through the bracket.
I thought I was going mad...thanks again!
paulwall
#18 Post by paulwall »
I've become obsessed with flossing since I got my braces in early May.
I use a combination of regular floss, interdental brushes (Dentek) and a Waterpik Aquarius with the "pik pocket" tip.
cauchy
#19 Post by cauchy »
I usually use Oral-B Glide floss with a separate threader, but sometimes I switch it up with Oral-B Superfloss since the built-in threader is easier to maneuver.
NikNax
#20 Post by NikNax »
I've purchased all types of floss, brushes and threaders. However I haven't gotten the Waterpik but it's on the list as I hear I should have one. But until then, I have fell in love with the spam spam spam flossers. I started using them shortly after I got my braces because I was really having a battle with the other floss. They fir nicely behind my wires. The first few times I used them, it took a while to get the hang of it. But now, flossing has become a breeze.
BraceEmilyB
#21 Post by BraceEmilyB »
I use oral b satin tape :jump:
Braced on 25th January 2017
Estimated time - 18 months
assertives
#22 Post by assertives »
I use a regular floss. I'm loving Dr Tung's smart floss. That floss gets everything out!
EmilyTravels
#23 Post by EmilyTravels »
I accidentally bought a brand of flossers from Walgreen that would not fit under my wires, so I have now ordered a big quantity of P L A T Y P U S flossers, which I know work since my ortho gave me a few to start out with. I also have a Waterpik.
EmilyTravels
#24 Post by EmilyTravels »
assertives wrote:I use a regular floss. I'm loving Dr Tung's smart floss. That floss gets everything out!
How do you get it under your wires? Or are in you in Invisalign?
assertives
#25 Post by assertives »
I have regular metal braces. I just thread it under my wires. I started out using the floss threaders, but I've kinda gotten the hang of getting it under my wires without the threaders after awhile.
EmilyTravels
#26 Post by EmilyTravels »
You are lucky! Most of my teeth are so tightly spaced, even the floss threaders wouldn't work. :( So it's flossers for me.
kuclas
#27 Post by kuclas »
I just use the regular oral b glide floss I get from Costco stir.
LittleTooth
#28 Post by LittleTooth »
oral b glide from costco as well. I tried other types of floss and I don't like the feeling (feels like scratching your nails on blackboard, makes me cringe). I always tie one end to a threader and it makes it so much easier. It takes me only 5mins to floss. To be frank my teeth are 99% of the time clean and food doesn't get stuck in between teeth and very rarely around the brackets.
cakers
#29 Post by cakers »
I am still super new to braces and I really like the Oral B Glide with a built-in threader.
EmilyTravels
#30 Post by EmilyTravels »
I use regular waxed floss between the back two molars that don't have brackets, and flossers for braces between all the other teeth.
