Which Waterpik tip do you use?
Re: Which Waterpik tip do you use?
standard ortho pik
I use the Waterpik Sidekick, very easy to travel with!!
I use the standard tip and the ortho tip. I like the ortho tip on a low setting to get everything out from around my brackets after I eat. I use the standard tip morning and night to clean the gums on a little bit higher setting.
which tip is the best for everytime? Please Ensure that I can find it on online stroes like, amazon etc.
Thank you,
E.Brown
Thank you,
E.Brown
I have this: https://www.amazon.com/gp/product/B07NQ ... UTF8&psc=1 and I use the ortho tip
I use the ortho tip nightly after flossing to give my brackets a good scrub, then switch to the regular tip to blast out anything the floss missed.
