Should I get braces for the THIRD time?
RedDress
#46 Post by RedDress »
VA5 wrote:I don't understand that statement fosterp.. that we shouldn't be making suggestions that only qualified professionals should be making. I mean, almost every post in this board involved a question that we are not qualified to really answer. We're all here just to give our input based on the experiences we have had, or simply just to give our opinions flat out. Whether or not the poster follows our advice is at their discretion, but I think most people know better to know that we are not trying to act like their orthodontist or any other professional. If I see a weak chin, and you do not, then that is all the more reason for her to see a professional if it continues to bother her. It's obvious we are not professionals but I am merely giving her my layperson's advice based on the limited information we can garner from a simple forum.
In the end advising a consultation with an ortho = same as adressing ortho treatment is no better, since, like you, Fosterp, say " you are not a periodontist, how can you possibly know the state of her gums and bones".. how can you advise such a thing?
And anyway, bad orthos exist out there as well as bad plastic surgeons. Do you think a bad ortho can produce less harm? What about messed up bites, bone losses resulting in teeth losses? Ever heard of such things? You think that is healthy?
Well, if not, why do you sending the girl to an ortho?
Why are you assuming that an ortho treatment will be healthy for her? What if she meets an ortho who promisses her golden results and then do something wrong?
My point is not to push for plastic surgery by any means, I am just responding to your post using your own logic.
RedDress
#47 Post by RedDress »
fosterp wrote: As she has already made clear that she issues with her appearance, someone suggesting things to "fix" her which may be wrong may only lend to increase her insecurity. Additionally, suggesting problems with her that don't even exist, such as a weak chin, only further damage her self-esteem.
Well, if you are willing to show mutual respect and keep the conversation in a civilized manner, then let's pay attention to what we actually say.
And what Jadore said. She clearly said she did not like her profile.
Some people later on said that messing up with teeth too much (like having braces for the third time) can be bad for your teeth.
I added: may be , if messing up with teeth is actuall turns out a bad thing she can change her profile in some other way. May be she could change the chin.
I did not point out to a new problem, I only pointed out that there are other ways to change the profile. And like VA5 pointed out, we here assume that the OP has common sence enough to get consultation with a lot of professionals about actual treatment and what can be actually done and does not expect that professionals are sitting here on this forum and look forward to us asking them questins.
Lynette
#48 Post by Lynette »
jadore714, If you were to get braces again you would probably need extractions to create enough space to move everything back. Also, take into account your smile will probably not be as wide as it is now and might turn into a 6 teeth smile (where only your front 6 teeth show when you smile). Not to mention the cost and 2 years you will probably be in braces for.
My case is actually the opposite to yours. The first time I had braces, I got extractions and my ortho moved my teeth right back so I wouldn't have any protrusion. Sure my teeth look straight and everything, but I was left with a 6 teeth smile and it took so much smiling effort to just show a little bit of teeth!!
My current ortho is now moving everything out and forward and sure I have a tiny bit of protrusion, but I'm happy that you can actually see my teeth now when I smile :D
Honestly, I think your teeth look great just how they are at the moment :)
Not need for jaw or chin surgery or anything!
23 year old female with ceramic braces.
http://www.projectbraceface.wordpress.com
Locked
