HelloJus wrote:tifqureshi wrote:smithy wrote:Hi kelhen,
Same here, just found this forum its great. I've had my IA since 4th June and have composite blobs on the front and back of the tooth that required the most movement. My Dentist said that the composite blobs were to stop the bars rising on the front of my teeth & falling on the back of my teeth.
Hi Tif,
Can you answer my question please. As i mentioned above, i've had my IA since 4th June. It took a few weeks to notice any movement, but by August, the movement had been pretty dramatic. Howver, since then there's been little or no movement which is becoming increasingly frustrating. Each visit i make to the dentist i'm told i should bear with it, however I think there needs to be more intervention to get the movement back on track. Is it normal for the inital composites to stay where they are for the full treatment, or should they be reviewed and replaced according to the progress. Any help you can give is appreciated.
Thank you.
Hello Smithy
Obviously its very difficult to comment on your case without seeing you but, it maybe that the aligner needs to be adjusted a little to increase the force. Sometimes some of the movements that are happening are not always totally apparent to the patient but may still be essential.
Composites can stay pretty much in place throughout but yes sometimes we do move them to other teeth as the teeth start to align out.
I have pm'd you
Kind regards
tif
Hi Dr. Qureshi
Welcome to the forum:-)
I have a question for you:
I've been wearing the inman aligner since the middle of august and is already very much satisfied with it! My ortho told me that I'm more or less done with half of the front teeth side, but the tooth next to my fronttooth still needs to be pushed a bit forward. Anway she put composite blobs on my canines aswell in order to make some kind of pressure on them which maybe will make them move a bit so they will be rotated in the right position as the rest of my teeth. Does it make sence what I wrote?
I was then told that if this wouldn't work then we would have to go for the invisible retainer (looks a bit like the Invisalign, I guess it's the same princip) but will this thing really make my canines move into the right position? I mean will this invisible retainer really make them move, and how much time does it in general take? I guess the treatment time will be longer than for the rest of the teeth that was done with my IA because the pressure with this one won't be as "strong" as with my inman, right?
Regards from Scandinavia
It is certainly possible to use clear aligners after the inman to perform final movements. They often work far better after and Inman Aligner because the inman mobilises the teeth nicely. To rotate your canines might take a couple of clear aligners, but it should work well after the Inman as long as they are fitted immediately.
you may actually find the pressure a little higher because clear aligners are far more rigid.
Generally lower forces means faster movements- hence why the Inman Aligner seems to work so quickly
regards
tif
