hey everyone- quick update of today's second adjustment!
first off- I got my lifters sanded down to virtually nothing! yippie! basically, she was going to remove them, but after checking out my crossbite on my right side, thought it would be bettter to leave them in for another month so the sides of my teeth don't disrupt the movement/grind/etc.
but I FINALLY got my actual bracket! [cheers!]
I forgot that they have those funny colours on them initially until they wear off- I didn't notice until I took the pictures
taking my preliminary bracket off was
horrible! that little sucker would not come off!
... I thought they would use some sort of debonding solution, but instead she used pliars o_o.... the assistant took several go's at it- then called the ortho over- I'm just so happy my tooth wasn't soar
beforehand, because it sure is now! o_0...
got some new wires too- especting pain tonight~! so far so good, minor discomfort when I bite down- but it is to be expected- my ortho was shocked at my progress- she said it was very quick and she was surprised and showed everyone my before pictures in awe!
My next battle is my cross bitw- and my teeth shifting to one side- if you notice, to make room for my incisor- my teeth moved forward and sideways- moving my front teeth out of center position- as such I have a large gap in between my front teeth until they come down a bit- I'm just so happy to have a tooth
sometimes when I walk by a mirror- I forget which side I'm looking at, because before I could just smile and either see a gap or not!
smile as of today- check out my new bracket! I think I have a larger wire too- she said "low torque" doesnt' that mean less movement? this thing looks huge!
top portion- looking good! I don't know why, but it is really hard for me to get a decent picture of my crossbite- you can notice the crowding on my right hand side [picture's left] and compare the width between each bracket and notice- other than that, I need to find a better picture
here's a good one! notice the gapping?
comparison shot- first is my left side, then right side
bottoms- looking pretty straight I must say!
