There are no stupid questions, just stupid people.
A quick question for you. I couldn't find the answer here and my brain was not engaged sufficiently at the time to ask my ortho.
I'm guessing the answer is no, but I'll ask anyway: Is using an electric toothbrush with a power chain OK, or should I revert back to old school manual operation?
Thanks
Shagers
Shagers - Braced Aug 05
Lipton Mr T - finally, a tea for the real man. I pity the coffee drinkin' fool.
I have a sonicare toothbrush and a powerchain. I've had no problems at all. The most important thing is to make sure you're cleaning thoroughly. If you feel you can do a better job with the manual then use that!
Braced: Jan. 17, 2006
Removed: Oct. 26, 2006
Fixed bottom retainer
Clear Essix Retainer on top
