I'm confused.....ligs..wire ties....
Are wire ties just placed on certain teeth to accelerate movement or can ligs do the same thing with the different configuations when placed on the brackets?
Have two wire ties placed on the upper two front teeth "to separate them and speed things along"....I like the look and the fact they aren't staining like the ligs on my others......But they sure do ache more!
Is it a mechanical decision or just Dr.'s preference?........
Are wire ties just for additional movement?
Wirednana (Deb)
I had two wire ties put on my bottom teeth, and judging by the amount of pain they initially caused, I'm guessing it's for movement.
If you have metal braces you could try silver ligs. My wire ties aren't noticeable because there isn't any other color on the bottom.
Braced on 17 Feb. 2006.
Five teeth extracted on March 9, 2006.
Canine exposure: February 7, 2007
lefort 3 March 7, 2008
TPA April 22, 2008
2 years 7 months in braces
braces off September 17, 2008
TPA April 22, 2008
I've had wire ties no ligs at all for my entire treatment thus far..my ortho has never even mentioned using ligs..i'v ehad no trouble with them and great movement..
crowding, mild overjet, and crossbite
SARPE AND R.P Expander: 7-14-05
extraction : 9-15-05
Brace date: 9-29-05
Expander out! 1-12-06!!!!! after 6 long mos.
Taking them off!!! Feb 26, 2007
http://www.archwired.com/phpbb2/viewtopic.php?t=5209
Brace date: 9-29-05
Hi WiredNana - I've just seen this thread - I've replied to you about this in the 'wires ties rock' thread if you want to take a look. Hope you see movement soon!
Music in the soul can be heard by the universe
![Image](http://tickers.TickerFactory.com/ezt/d/4;10713;112/st/20051003/e/Since+Uppers+Went+On/k/9f91/event.png)
Upper ceramics: 3 Oct 2005, Lower metals: 1 Nov 2005
Braces remove: April 4, 2007!
I have had wire ties once on one tooth. I have damon3 which are self ligating so I don't have to deal with this much. I can tell you I found the wire tie to be quite annoying when you go to floss because the floss just gets ripped to shreds. Anyone with wire ties have this problem?
Mid Forties!
Mid Forties!
My wire tie has never caused me any problems. My ortho always twists it really tight and cuts it pretty short. He then hides it really close to the bracket.jcdamon3 wrote: I can tell you I found the wire tie to be quite annoying when you go to floss because the floss just gets ripped to shreds. Anyone with wire ties have this problem?
![Image](http://tickers.TickerFactory.com/ezt/d/4;10722;104/st/20070208/e/14th+adjustment/k/2f6d/event.png)
