Today when I went to my orthodontist to get my braces on they gave me these flossers. They've got a stiff wire to get in under the wire, then a spongy part to clean the wire, and then the actual floss. I could NOT get these things to work! I finally just gave up.
I know flossing is really important. Is there anything else I can use that's easier?
Flossing
Bending the tip is a great idea. Part of the problem was feeding it through the wire.
My biggest issue is using the floss. My mouth is very small and its really awkward trying to get behind my teeth to floss. I've never used regular floss before - I used this thing that had a body like a toothbrush and the head was a threaded flosser. I guess what I'm looking for is something like that.
Floss
get some of the glide threader floss, and you wil not look back.
Each box has 30 individually wrapped pieces that have a threader at one end.
My advice is to get used to putting you fingers in your mouth. A great deal of time can be saved once you learn how to move the floss
For example when flossing the uppers: push the thread up through the gap in the brackets while you pull you cheek away from you teeth. While holding it through with the cross hand, take a finger and place it on the floss above the brackets, slide it forward with you finger
The same can be done on the bottom, but instead you will be threading downward.
hope that helps.
hope that helps.
Oh sure, I see Bart gets to have a gun. - Homer Simpson.
