How long before bottom braces can follow the top?
I had my upper teeth braced just over a month ago. They couldn't put the bottom braces on at the same time because, with the way my jaw closed, I was in danger of biting the brackets off.
I'm going in for my first adjustment tomorrow, and I'm curious about how likely it is that I'll get the bottom teeth braced tomorrow too. Is this the sort of problem that can be resolved that quickly (ie, within 5 weeks), or should I expect several more months of being wired on top alone?
As everyone else has noted, we all have a different treatment plan...so the best person to give you the best answer really is your ortho.
Nevertheless, I was going to get both my uppers and lowers at the same time, but at the last minute, my ortho decided to only brace my uppers.
His reasoning wasn't because I could have broken lower brackets or anything like that...he chose to not put my lower ones at the same time because they didn't need much work...and he wanted my upper teeth to catch on to my lower ones...
So I got my uppers in Jan. and my lowers in May.
There's a possibility I may not need braces for my lower teeth. My orthodontist said he may be able to get my bite corrected without the lower braces. He said he will know about 4 months after my upper braces are placed. At this point, if I need them, I don't have a problem getting braces on my lower teeth too. I just got my upper braces recently so I won't know until about 4 months.
I had heard for some people, they don't need the lowers on as long as on the upper teeth so the lowers are placed a few months later. I also think this is a great way to adjust to having braces.
ssfw
ssfw
Braces removed: 8/19/08
Next appt.: 11/18/08
For me my top braces will be going on first, then at my first or second adjustment my bottoms will go on. My ortho explained that because I have a class 3 mallocclusion if they started to straighten both at the same time, my bottom might unravel faster than my top can and push my bottom teeth forward enough to potentially cause a crossbite. To prevent this he wants to give my tops a head start. All that being said, I really hope that he decides to do both arches at once instead. I know my bottom needs more work than my top so I'd like to get it started.
Just like everyone else said, everyone is different! Me, being the "complicated case" that I am
my ortho didn't put my lower braces on for 18 months!
I think this was because of my 2 impacted canines and my deep bite!
~Hannah
Top braces: 4/28/04
Bottom braces: 11/16/05
~Hannah
Top braces: 4/28/04
Well, I guess I'll be different on this. I got my uppers and lowers on the same day - back in October, 2005. It seems like the ortho has been alternating changing the wires. Sometimes, I get only the upper wire changed, sometimes I get only the lower wire changed and less frequently, I get both changed.
P. S. I love Nova Scotia. Great scenery, great historical sites.
In my case I had both sets placed the same day. Althought the top needed less work than the bottom. So far the top teeth have hurt 100 times worse than my bottom teeth. I just had an adjustment yesterday and my top teeth have been hurting since. But everyone is different and only your ortho would know.
