I've posted in the past a little bit here and there but this is my complete story. As a child, I never got braces because my teeth were more or less perfect. I got various opinions and all said that it was not worthwhile to get them. My jaw is quite narrow and the only thing they recommended was jaw surgery - which I was not getting.
By age 20, as my wisdom teeth grew in (which I was advised NOT to get out), 3 teeth on the left side of my mouth began to push in. Eventually, I had a crossbite. By age 21, I desperately wanted to fix this as one tooth in particular looked pretty bad from front on. It looked almost like I was missing a tooth. I would never have gotten normal braces and thankfully, I was a candidate for invisalign.
I started in June 2005 with 24 aligners. I wore each for 2 weeks, had some attachments, never had a revision, and never had a problem. Today, I have FULLY completed my invisalign treatment! I wore my last aligner for 6 weeks as my ortho wanted to make sure everything was settled in. Today, I got permanent wires across my front 6 top and bottoms.
I am attaching before and after pictures posted below. You can see the most drastic change is the 3 teeth that were taken out of a crossbite. The after pictures were taken before the attachments were taken off.
Ya, maybe my teeth aren't totally perfect, but I am completely and utterly thrilled. I love my smile again and do not have one single regret regarding invisalign. There are a lot of negative posts out there and I almost backed out after reading the bad press. Do not let it get to you, because Invisalign really can help - just look at my case.
Positive Invisalign Experience
looks really good i think my treatment would be as good as yours except for the fact iv had 4 extractions and some of the molars are tipping i wonder if my ortho which i see in a week will still say everything is fine like she did last time when i know deep down that i will most likely need a fixed brace at the end to correct my molars but i would never have had treatment without invisalign so even if it costs me the earth i do not care i just want to be able to
Invisalign success
Wow - your teeth look fantastic! thank you for posting that info. It gives me hope! Who cares if Invisalign costs too much? You must be so happy. Good luck always!
-Tracy
-Tracy
