I'm new, a 30 years old male. I'm new to this braces stuff. I've never had them but decided to do so now since I have a job and can afford them now.
I went to a doc today. He said: Got to take out 4 teeth (premolars: two in the bottom, two in top), $5000, Metal braces (Invisialign cant do it), 2 years treatment plan.
When I came back, I saw found this website:
http://www.speedsystem.com/HTML/user_su ... ase04.html , which showed a before/after case:
I did search on this forum but couldnt find any information on this "Speed system". How can these teeth move in just 4 months?Before:
After just 4 months:
What should I do? I want to get my teeth straight in 6 months - that would be nice. I dont know if I'm going to stay in this city for the next 2 years and I heard transfers are difficult - they usually want to start over again. Plus 2 years of braces seems so painful and inconvinient.
Here are some basic pics as my teeth are right now:
The back teeth are fine, its just the front ones. Two teeth are hugely out of whack, as you can see - one in the bottom and one at top.
So I dont understand, if those before/after teeth were able to move so fast, why isnt everyone doing them?
