Is your Waterpik crazy loud?
I got one for Christmas and I'm amazed at the sound that comes out of it. It works really well, though. Just wondering if the noise is normal? Its an all white counter top model with 3 normal heads and one for your tongue.
Thanks!
Thanks!
Was braced for all 9 months of my pregnancy and managed to keep fresh elastics on during all 26 hours of labor!!
I'm glad I'm not the only one who noticed...LOL. For some reason I didn't expect it to make such a ruckus, but it does. So I have to use it before everyone goes to bed.
I'm thinking it's normal, but at the same time it doesn't feel like it...sputtering all loud like its about quit on me...LOL...
Mine works good, too. I don't know how some ppl make it with braces without one!!! I got the blue and white Waterpik Ultra. It came with 8 tips...3 standard, 3 tongue cleaners, a Pik Pocket tip and an orthodontic tip which I like a lot.
Just wish it was a little quieter...haha...
LiFe iS A HoOt iF You arE aN oWL...O.o
Sept. 28 ~ Consult with Orthodontist
Dec. 5 ~ Spacers In
Dec. 12 ~ Braces On!!!
Dec. 5 ~ Spacers In
I just bought an Oral-B Vitality Electric toothbrush and its louder than I thought, too. I can't use it tho my teeth are so very sore from my "mini" adjustment...boo hoo... Pain is good tho...means things are moving...yay movement!!!...
Dec. 5 ~ Spacers In
Dec. 5 ~ Spacers In
my waterpik is so freaking loud that my dog barks at it when its on!
like turtlelove, i keep expecting to die on me... no problems yet
and I love the thing.. WP-60W
can someone explain to me why i get all sorts of teeny pieces of food falling out when i use it after I think i have flossed and brushed thoroughly?? now i cannot see myself live without one even post braces. i won't know about that for another two years....
The pamphlet that came with the waterjet said to aim at 90 degree angle to your gumline.
It can also be because you are flossing and brushing well. Bits of food falling out of your mouth after a whole cleaning procedure leads me to believe that I am just not doing a good job cleaning.
It can also be your teeth as well. I've got a crowding problem, which leads me to believe that there are just more spots that floss and my toothbrush can't get into to really get the gunk out.
Re: Is your Waterpik crazy loud?
[quote=Ravishing post_id=144568 time=1167255536 user_id=4921]
Thanks!
[/quote]
For your question, I suggest you use [url=http://www.SPAM SPAM SPAM SPAM SPAM SPAM SPAM SPAM.com/]water flosser[/url].
Thanks!
[/quote]
My young kitten got the crap scared out of her the first time I turned it on glad I'm not the only one. I guess I'm doing the Waterpik wrong. I tend to use the Waterpik first, then brush, then floss, then tongue scraper, then mouthwash. Should I be using the Waterpik post floss?
