ok so i had 2 teeth pulled and they're pulling my front top teeth back to fill in the gaps
but i swear they're running out of room.
they are already hitting the bottom teeth, making it very annoying since im not used to that and every once in awhile my bottom ones hit the top ones really hard...
which hurts so bad
also another thing, when they make me bite down at the ortho, they always push my jaw really far back... which makes me think that in the end, thats where my jaw is going to be sitting...
but that position is so uncomfortable, and doesnt feel natural
im just wondering if anyone else has experianced this and if its normal
teeth running out of room?
I think I know what you mean, Trequ; I had 2 x upper second biscuspids removed and have been waiting on the gaps to close to retract my overjet.
The original idea was to use IPR to create a little room in the bottom arch to pull them back too, however my ortho hasn't done any IPR (or anything much at all) to my lower arch yet.
Initally my treatment time was meant to be 14mths, meaning I am due to get debraced in about 1.5 mths, however I wouldn't be happy if he tried to deband me then. So far one extraction gap has closed but the other is still wide enough to fit my tongue in (and has barely moved at all in 6 weeks). More concerning (for me anyway) is the fact that my molars still don't fully touch, making chewing difficult. Right now when I bring my uppers and lowers together naturally, I can fit my tongue between my first molars on both sides
Trying to make my molars meet properly (or as near to as I can get) requires pulling my jaw back as far as I can, which feels very uncomfortable.
I know what you mean about unexpected top and bottom arches clashing painfully. I guess it takes a little while for your muscles to get used to the new teeth positions, especially since they were in the old positions for so long, and the new position seems to change daily!
I guess all you can do is mention your concerns to your ortho (something I'm trying to do with mine!).
Good luck with your treatment![ThumbsUp :thumbsup:](./images/smilies/thumbsup.gif)
![Confused :?](./images/smilies/icon_confused.gif)
![Image](http://tickers.TickerFactory.com/ezt/d/4;10722;450/st/20121220/e/TMJ+splint+fitting.../dt/16/k/19e5/event.png)
![Image](http://tickers.TickerFactory.com/ezt/d/4;51;2/st/20130423/e/CD+Advancer+placed.../dt/15/k/ac5a/event.png)
![Image](http://tickers.TickerFactory.com/ezt/d/4;2;2/st/20130802/e/Lower+Braces/dt/14/k/1cb2/event.png)
![Image](http://tickers.TickerFactory.com/ezt/d/4;15;126/st/20131122/e/since+Upper+Braces/dt/16/k/0a54/event.png)
