Cheap Sonic , expensive Sonic, any difference?
Over a month in my braces and I still can't make a decision on which toothbrush brand to purchase..I tried for under $5 The colgate sonic..I didn't like the feel of the sonic vib against my teeth/brace...Am I supposed to brush normally with those. Is there a huge difference is sensation with the expensive sonics? How do u brush with a Sonic..Just leave the toothbrush on the brace and let it do it's work? ugh so many questions sorry.
Has anyone tried the Oral B Vitalitys or any Oral B electric?..oye another question..lol
I've never tried the Sonic line... I swear by my Rotadent--yes, it is expensive, but it's so worth it. I just got back from an adjustment and once again I received high marks in the brushing & flossing department.
I know my brother just loves the Vitality I bought for him... whatever brush you decide on just make sure it's one that works for you!
Metal Braces: August 18, 2006-January 14, 2009
Essix-type Retainers: January 14, 2009--present
I can't comment specifically on the Colgate Sonic brush. It looks like it might be available in Canada but not in the US?
But, I switched from a Crest Spinbrush, which I received in my ortho goodie bag, to a Sonicare 7300. And, the two of them are LIGHT YEARS apart! I love my Sonicare (and I know that are others who don't love Sonicare but love their Oral-B's) and feel that it does a much better job than the Spinbrush. I bought my Sonicare off Ebay, so the price wasn't too bad.
My non-brace-wearing husband is also using the Sonicare now - his dentist said he was wearing the enamel off his teeth with the manual brush.
I have an oral b sonic. I don't think there is a huge difference between brands, it is just a matter of what you get used to. I got mine just because I was walking by in a wholesale club and it jumped off the shelf all by itself. As to the difference between a cheaper model and a more expensive model within the same brand, I tend to think you get more cleaning power with the higher end product. The latest tech stuff always costs more....now as to if you need it..... No, you don't NEED it. I do feel I get a better clean with my sonic than with my manual. Last but not least - the sensation - it does take a bit of getting used to. When I first got mine (pre braces) I swore up and down about how much I hated that little sucker, but I had spent so much money (I am truely cheap at heart) that I wasn't going to give up without a fight. After about 2 weeks I was hooked. Start with the lower speed setting and work your way up. When you think about all of the ways you can blow 80 bucks (cute shoes, dinner+ wine, junk you don't need at wal mart that just looks so fun,) this is pretty harmless.
Thank you KK, I'll do that! In 3 hours I'll be on my ortho's chair. I'm getting more and more excited by the minute.
I'll ask my ortho to show me how to brush and floss. I've been doing it all wrong then I use an automatic one and I use it like a manual. But it's not that strong, is weak. Oh, gosh, feeling quite stupid right now.
I see an e3000 Sonicare at 30 bucks shares the same kind of brush head with other expensive e-series Sonicare's. So, e3000 should have similar result. I bought one and so far I'm happy with it. I feel my teeth much cleaner than when I use the Spinbrush. My sister loves her Oral B toothbrush. I think the choice is just personal preference.
Full Metal Mouth
I have the Oral-B Vitality Sonic... I love it It only cost me $18 here in NM, USA... I am so glad that someone asked how to use a sonic toothbrush, b/c I have always used mine like a manual, too... I have had some gum irritation lately, so I think that may be the culprit... I will try to brush the proper way, and see if it clears up! Thanks everyone
Just wanted to mention one thing ... my sonicare manual says to hold the bristles at a 45 degree angle so that the bristles point up at the gums (assuming the upper teeth) or down at the gums (for the lower teeth).So how do u brush with a Sonic?
I believe this is to avoid hurting your gums. It is a technique that two hygienists recommended to me for using a manual toothbrush as well.
See pages 7 & 8 of:
http://www.sonicare.com/owners/essence_ ... 015373.pdf
Page 8 also has a suggestion for braces.
Overall, I really like my sonicare (essence 5300); compared with manual brushing, it is much easier to use effectively.
Damon 3 Top 6/21/06. Damon 3MX Bottom 11/7/06.
