Sanding my teeth????
I just went in for my first adjustment...my lowers are still crowded and my doctor replaced the elastic bands on two of my pushed back teeth with metal wires. He said once my teeth pop forward, he'll be narrowing the tops of them so they fit better. My teeth are shaped like an upside down triangle and he said when they're side by side, I'll have gaps at the bottom by my gums. Has anyone had this done? Does it hurt? I'm a big weenie when it comes to anything remotely resembling a drill (bad experiences in the past...no matter what they did the numbing didn't work...) What do I have to look forward to???
Hey!
I had this done at my last adjustment, and it was nothing to worry about. I worry about everything and i hate pain, so was nervous about this. But if im honest i didnt even know what she was doing, until she asked me to choose colours (best part) and i felt a gap in between my front teeth!
(if i looked correctly it is a tiny tool that has two sides to it, on to do the main sanding and the other is a polisher)
The worst part is the smell, (i thought it was the horrible glue again) but i would choose a horrible smell over pain any day!
Really nothing to worry about, its excellent you can see such a huge difference after it is done.
Good luck
Amy
Good luck
Amy
