GETTING BRACES
GETTING BRACES
im getting braces next week what will happen ? does it hurt the whole process someone i need some advice thanks
ALSO I NEED TO KNOW CAN YOU GET LIKE CAVITIES AND EXTRACTIONS WHILE YOU HAVE BRACES
Hi lovedog,
Check out the Newbies section of this board viewforum.php?f=18 for information on what happens during the procedure and other stuff you might want to know going in. The process is painless. You may experience a little discomfort here and there, but nothing you can't handle. In my experience, I thought I was going to fall asleep while they were putting them on and only experienced the slightest bit of discomfort the next morning (for about 5 minutes). You may want to use the search feature on this board to find posts related to getting braced and anything else you have questions about. Chances are, if you're wondering about something, others have too and have discussed it here.
Good luck with your braces!
I'll second what jenny5 has said.
It is possible to have extractions while in braces and many of us have had that experience. Discuss this with your orthodontist - it may or not be in your treatment plan.
As far as cavities are concerned, there is no reason why having braces should increase the risk of cavities developing. That said, maintenance of good oral hygiene is a good idea.
Re: GETTING BRACES
You will be fine. Read my blog at http://bracesafter40.blogspot.com ; note that it is different for everyone. I had no pain at all since I've had them in now for 10 days; I can now barely bite anything and chewing has gotten better. I've actually lost 10 lbs. I had to extract a tooth a week before braces day, so that helped with the weight loss as I could not eat much at that time.lovedog49507 wrote:im getting braces next week what will happen ? does it hurt the whole process someone i need some advice thanksALSO I NEED TO KNOW CAN YOU GET LIKE CAVITIES AND EXTRACTIONS WHILE YOU HAVE BRACES
My braces day post is here at http://bracesafter40.blogspot.com/2007/ ... s-day.html
_________________________
Top Braced on Feb 28, 2007
Bottom brace and 1st. adjustment of top will be on April 4, 2007
