Adjustment #3 for Double HeadGear Wearer (Pics)
jose
#1 Post by jose »
Hi..
Friday i went to my third adjustment after weeks of wearing my double hg.
I had been in the ortho office for an hour to adj the brackets and to add a sping in front of my tooth to open up space for my incisor to come forward.
This little Spring is making me crazy as it's giving pressure on my cheeck and I nead to put a lot of wax on it.
For the other they adjusted to a heavier wire up, they repeat the same wire down. They adjusted a little for stronger pressure on both my headgears.
Now I have a Cervical for bottom and a Combination HG for upper arch.
It's now easier to sleep even if sometimes I still wake up to take them out. The problem is that when it's happening I could not reach my 8 hrs of wearing them. And teh ortho noticed it and told me that if I will not be good I will need to get also a TPA next adjustment because my molars will move forward.
How is a TPA? Is it hard to talk with?
I will need it to be added and stay at my average 6 hrs with my double headgear. But the ortho told me that if I keep my two facebow in for at least 8/10 hrs a day It should be enough. But if I do not wear them enough I will need to add also a TPA.
I'm worried because the TPA is a fixed appliaces in the roof of my mouth and I hope it' snot interfering with speach.
Can you please let me know?
Already with the double hg in the night, plus fixed brackets , plus Springs and 8 molar bands it's already too many metal in my mounth.
Still drooling a lot in the night when wearing double hg and sleeping on my side...
Any advise also for that?
Here below my latest pictures taken after my last Friday Adj:
Ciao
Jose
33/M/Double HG/Metal Brackets up and down GAC model With a now a Spring and 8 molar bands (Maybe a TPA next adjustment)!
jose
#2 Post by jose »
Thanks for the advise.
I'm trying to reach more hours with these 2 headgears in!
Jose
jose
#3 Post by jose »
any help on the info requested?
thanks
Jose
JesseJames
#4 Post by JesseJames »
I have a TPA, at first i had no problems, than a week later i could talk but was slurry with S sounds, than i was back to normal for a few days and than it got bad again. Its been a full month now and i haven't had any problems the last 2 weeks, and i don't even notice it's there anymore.
Chances are it will hurt your tongue a bit eventually, but that really does go away fast. And when i say my speech was bad, it really wasn't, it was just slightly slurry, the slower i talked the better, and everything went normal again anyways.
Oh yeah, it'll be weird to eat for the first few weeks because everything gets stuck between the top of your TPA and the roof of your mouth. I dont know if i taught myself how to eat differently or what but i barely have a problem with it now.
So in other words, you'll probably hate it at first but it gets better!
cmm1280
#5 Post by cmm1280 »
I have 2 TPA's... Yes 2!! I got them at my last adjustment which was about 3 weeks ago. They are both aross the top on both sets of my molars. I only had a slight problem with speech for the first few days, but no one seemed to notice. Food was also strange at first, but got easy after about a week. I still get some things caught on occasion, but a quick swish around with water it is dislogged.
Just like with most things, it gets easier and you adjust :)
**Braced 22 months and 3 weeks. Estimated 24 months treatment time.
jose
#6 Post by jose »
thanks for your help guys!
Another 2 weeks to decide!
Thanks
Jose
chillin-in-grilz
#7 Post by chillin-in-grilz »
Holy smokes! :shock: Double headgear? Your a brave one!
Brace Free February 17th, 2009
Braces January 29, 2007
bracesafter40
#8 Post by bracesafter40 »
Jose
Quote: "This little Spring is making me crazy as it's giving pressure on my cheeck and I nead to put a lot of wax on it. "
I got one of those little springs on Wed. I am not feeling any pressure just yet. It is between two teeth on the upper right. Have not used any wax.
Here is a pic - Image
Good on you with the double headgear; I hope you get the desired results.
Nice pics; have you seen any changes since you started your treatment?
What is a TPA and what is it used for? Why would you need one?
http://bracesafter40.blogspot.com
Bridge Sectioned: Feb. 14, 2007
Last Pre-braces cleaning: Feb. 20, 2007
#21 Extraction: Feb. 20, 2007
Sentenced: 32 months
Top Braced: Feb 28, 2007
Bottom Braced: Apr. 4, 2007
New Ortho on Apr. 25, 2008
May 6; fluorescent blue ligs incl. upper powerchains. 2 elastics; Sept. 2, 2008.
Next Adj.: July 7, 2009 at 8:30a
jose
#9 Post by jose »
The TPA is a TransPalateArch that connect the two upper or lower molars between them. Normally is used to keep molars in their position.
In my case actually I dnot have them yet, as my ortho is trying to keep my molars in teh place with these double headgears, but if they will go forward then the TPA will be added.
For the moment I see some movements and the worst of all my traitment was to adapt to wear this double headgear, with teh facebow inside my month.. It was very hard to sleep at the beginning!
Thanks
Ciao
Jose
HeadgearJoe
#10 Post by HeadgearJoe »
good luck with the TPA
braces off 1/31/08 wearing bonded retainers with a nightsplint, will get removable hawleys 2/21/08
