One of my bracket became unglued. The wire is the only thing holding it from falling out. Has this happened to anybody. I sure hope my orthodontist can see me tomorrow to glue to back on.
This stinks - I made it 6 months with no problems and now this.
My bracket came loose
No...I don't think they would want you to wait 6 weeks to get that fixed;) That is a long time for that tooth to miss out on movement! Plus, if you have an archwire change scheduled for your next appt. they might not be able to progress to your next archwire if that tootj isn't where they expect it to be. Give them a call...I am sure they will be more than happy to schedule you a quick appt to put that back on;)
![Image](http://tickers.TickerFactory.com/ezt/d/4;10728;133/st/20070420/e/braces+came+off%21/dt/-1/k/7dbd/event.png)
*~Currently retained in:
-Upper and Lower bonded retainers
-Upper QCM Hawley
-Damon Splint (night)
-Postitioner (as needed)
~*Orthodontic Assistant*~
Re: My bracket came loose
Tracy, call your Ortho immediately. I lost a bracket last Friday and had it replaced on Monday as they were not available until then. Loose brackets delays your treatment, so get back in that chair as soon as possible. Mine really poked me all weekend.tracy729 wrote:One of my bracket became unglued. The wire is the only thing holding it from falling out. Has this happened to anybody. I sure hope my orthodontist can see me tomorrow to glue to back on.
The initial missing story - http://bracesafter40.blogspot.com/2007/ ... acket.html
The repair story - http://bracesafter40.blogspot.com/2007/ ... r-now.html
Good luck with it; 6 weeks is too long to wait to get it glued back on!
Bridge Sectioned: Feb. 14, 2007
Last Pre-braces cleaning: Feb. 20, 2007
#21 Extraction: Feb. 20, 2007
Sentenced: 32 months
Top Braced: Feb 28, 2007
Bottom Braced: Apr. 4, 2007
New Ortho on Apr. 25, 2008
May 6; fluorescent blue ligs incl. upper powerchains. 2 elastics; Sept. 2, 2008.
Next Adj.: July 7, 2009 at 8:30a
Got you KiwiK. I talked with my Ortho about this very thing when I got my bottoms and she told me that losing a bracket will slow things down as that bracket not being in place will not allow the tooth to move properly.
So when I lost one a day later, I called right away.
Just an update
I called my ortho's office this morning before 9am and had an appointment at 9:30am. They replaced the bracket.
I still do not know what caused the bracket to pop off.
Oh well - here's hoping to another 18 months of no more broken brackets.
![Image](http://tickers.TickerFactory.com/ezt/d/4;50;0/st/20061205/e/1st+adjustment/k/88ff/event.png)
![Image](http://tickers.TickerFactory.com/ezt/d/4;10725;4/st/20061023/e/I+have+been+braced/dt/-21/k/eaa1/event.png)
