Raw and blistered :(
choowee
#1 Post by choowee »
A little over a week with this tray (#2), and I've noticed that the underside of my tongue and the inside of my lip is blistered and raw...!
is this common? its making me miserable, but i don't think I can make it to the dentist for quite a bit. :cry:
sandra
#2 Post by sandra »
Is the bottom tray rough under your tongue? If so, maybe you could file it down a bit?
I rinse with salt water a lot when I get this problem and it makes it feel better.
I think our mouths just need time to toughen up.
I hope you feel better soon.
sandra
#3 Post by sandra »
PIMPmyTEETH
#4 Post by PIMPmyTEETH »
due to the way the trays are manufactured, some trays are rougher in spots that other trays are not. before i put in a new set of trays, i always feel around all edges and file down all the roughest spots. over the next few days, i try to file down any spots that are still rough and aggrevating my mouth/tounge.
since you are only on tray 2, your mouth will probobly still toughen up a bit over time too. since i started doing my filing routine, i havent had any problems with soreness.
invisalign patient since feb 2007
upper trays: 25.
lower trays: 11+5 refinements.
now: bonded wires+upper essix.
jeni
#5 Post by jeni »
I agree with the posters above. When you find out exactly where it is bugging you, just file it down until the edge is smooth. I have only had to file 2 of my 6 so far. One was bugging me from the start and the other just started irritating me around day 3 and when I took it out there was a large gash and the plastic was folding back (must haven't got something caught in there at some point??).
choowee
#6 Post by choowee »
thanks for all the advice! water definitely helped, and the filing gave me some relief as well. But most of all, I think I needed time. Now I tend to forget that I have them in at all.... yay! :)
