Hi, guys,
i`d like to know if those of you who had their molar bands taken off had any gum issues , anything?
i`m always very conserned about my molar bands and scared, however my dentist said my gums were ok and i just had to keep on with good level of higene over there, but still, it seems to me like they would never come off, cause they are stuck in my gum and glued so hard on my teeth..
How many of you had your molar bands taken off??
I know it seems like those bands are really stuck on there. I thought they were on my molars as well. I had eight bands on all of my rear two molars as this is necessary for surgical patients such as myself. After surgery, the bands were removed so that the Orthodontist could put brackets on the molars to make it easier for her to make adjustments as brackets can be removed and repositioned easier. The bands came off super easy even with all that cement they use to hold them on. There wasn't any pain at all to remove them even with the bands seeming as if they were below the gumline.
Got braces? http://www.igotbraces.com
The orthodontic and orthognathic surgery support forum for everyone.
I had molar bands taken off. I was wondering myself how it would be done because they were cemented all the way around and it was such a tight fit getting them on in the first place, but they just took pliers and cracked the cement and wiggled them off. It sounds scary cuz you hear a big pop and you have no idea what it is, but my teeth ended up fine. The gums around one of the teeth got torn up a bit, but it healed afterwards and I have no problems now.
