Calling all 40something Jaw Surgery Vets
4beauty4symmetry
#1 Post by 4beauty4symmetry »
As some of you may remember, seeing as how I seem to have mentioned it a zillion times (<g>), I'll be having upper, lower, and genio in Costa Rica.
How long after your surgery--for those that have the trifecta, or triple layer enchilada--do you think it was before you would be up for an airplane flight?
My journey from Costa Rica to Boson would be broken into two--Miami or Huston stop over/changeover most likely--and would take 8-10 hours total transit time.
My OMS will say two weeks, but he's always conservative--originally after the Sarpe he wanted me to stay two weeks, but then four days after the surgery he examined me and said I could go back anytime. So that's why I thot I'd ask the "been there, done that" crowd.
Dec 2006--RPE followed by SARPE surgery
Jan 2007--Braces
Nov 2007 BSSO mandibular setback, genioplasty, and two implant anchors. Surgery-eve reprieve from Lefort.
May 2008--Debraced
Surgeries in Costa Rica, Orthodontics in Massachusetts.
All to fix an openbite, crossbite, underbite, and two missing bottom molars.
ohmyjaw
#2 Post by ohmyjaw »
I am a mere 20-something, but I don't know if I would have been able to manage a flight like that until about 7-10 days after surgery. (Mind you, I was very doped up on morphine and wired shut. Things may be different for you!)
Big H
#3 Post by Big H »
A genio and a chin implant? My understanding is a genio when done correctly is the preferred solution to a "weak chin" and done instead of a chin implant. Most individuals may opt for a chin implant if no other orthognathic surgery is necessary as it is an easy quick procedure that can be done as an outpatient with a small incision.
4beauty4symmetry
#4 Post by 4beauty4symmetry »
My mistake. I should change my signature. For months I thot it was a chin implant I was getting, then my OMS informed me I would actually be undergoing a genioplasty.
Like most underbiters, I have a prominent chin (or did until the Sarpe). The OMS sez that the mandibular setback will leave me with the appearance of a weak and recessed chin, an assessment disputed by none of the other orthos or oms I consulted with.
A bit flipped out now that I have the date. It would be much less stressful if I could have the surgery here--don't want the surgery to be a Big Adventure--but don't have much choice. . .
Jan 2007--Braces
May 2008--Debraced
