Spaces in between bonded retainer
tdc03
#1 Post by tdc03 »
Do any of you have spaces in between your bonded retainer? I'm not talking about black triangles, I'm talking about a 1 mm space in between teeth that are bonded with a permanent retainer?
Should I ask my ortho about this?
idolfan4
#2 Post by idolfan4 »
I have a tiny space between my central and my lateral incisor (on the right side), but I don't worry about it. It's so tiny, nobody even knows it's there. Even I don't know it's there. What's the point of getting upset over something so little? Anyway, if you want to ask your ortho about spaces between your teeth with your permanent retainer, go ahead, but if it's only 1mm, it's nothing to stress out about.
jennielee81
#3 Post by jennielee81 »
No spaces here.
I would ask your ortho about this if it bothers you!!!
Best wishes.
:D
