Poll: Wet toothbrush or dry toothbrush?
Lisa65
#1 Post by Lisa65 »
When I brush my teeth, I always put the toothpaste on the brush and then put the brush under the tap to wet it a little. I've always done it this way (probably because that's how my mum did it and I copied her) but I don't like the feel of a "dry" brush on my teeth anyway. My husband doesn't wet the brush, he just puts the paste on and then gets brushing.
So, who here is a wet and who is a dry brusher, and what's the reason behind your choice?
Just thought it would be interesting to find out.
dagwoman
#2 Post by dagwoman »
Wet- it feels better, and that's the way I was taught. I know some people who wet the brush first, THEN apply the toothpaste, which is just weird! :P
CactusZAF
#3 Post by CactusZAF »
I also wet the toothbrush after applying the toothpaste, I guess this is because I was taught to brush in this manner when I was young. I read somewhere or was told by one or other "expert" that you're not supposed to wet the toothbrush, but after trying to brush with a dry toothbrush on numerous occasions, I've decided to stick to the routine I'm comfortable with (it just doesn't feel right if it's dry). :lol:
skintz
#4 Post by skintz »
I'm a wet brusher, but i wet my toothbrush before i put toothpaste on...whats so weird about that?!! :lol:
MamaRoo
#5 Post by MamaRoo »
I put the toothpaste on and then wet the toothbrush...
Austin Stehling
wet brush
#6 Post by Austin Stehling »
I also wet the tooth brush first and then put the tooth paste on.
I wash it first to make sure its clean.
Austin
jgrrl22
#7 Post by jgrrl22 »
I actually wet my toothbrush, apply the toothpaste, then wet it again.
I have no clue why I do it that way... but I always have. LOL I never really thought about it before until I read your question. :D
browneyedgrl
#8 Post by browneyedgrl »
I rinse the toothbrush to soften up the bristles, put toothpaste on and then wet it again.
Lala7603
#9 Post by Lala7603 »
jgrrl22 wrote:I actually wet my toothbrush, apply the toothpaste, then wet it again.
HAHA.....thats is seriously the exact thing i was going to say!
Braces On: November 21, 2003
Braces Off: December 17, 2004
Braces Back On: November 6, 2007
Braces Back Off: 2008
Delag
#10 Post by Delag »
You have to get it wet first - you get better bubbles that way :D
lionfish
#11 Post by lionfish »
I do what you do, lisa, habit of a lifetime.
Lana
#12 Post by Lana »
Haha
I do rinse the brush first to clean it off and to soften the bristles. Then i put toothpaste on and brush. I used to wet tootbrush after putting toothpaste on but not anymore. I can't remember why i stopped though...hmm..
mottsrods
#13 Post by mottsrods »
Howdy all,
I also wet the brush, put toothepaste on it, then brush.......here is why I think I do it this way.......toothepaste bubbles and joins with your saliva as you brush, as you do this, the bubbles and saliva work there way into the nooks and crannies of your mouth better, and get it all very clean........I will also tell you I just tried it both ways just so see if there was a difference.......And....there is......
Mott
Stick a fork In me.......I'm Done!
ilovemacs
#14 Post by ilovemacs »
I wet, then apply toothpaste, then wet once more! :D
I think I was brought up that way. :D
Ruby Tuesday
#15 Post by Ruby Tuesday »
I'm happy to be the odd one out on this one! I am a 'dry brusher'! I use the brush dry, try to kind of distribute it all around my teeth, and then, because I have a LOT of saliva, my mouth is very quickly overflowing with paste and saliva. Sounds gross I know but anyhow that is it. There would be no paste left if I used a wet brush..
