well THAT sucked..
avl
well THAT sucked..
#1 Post by avl »
now i see what some of you are talking about with trays that are hard to remove or put in. im on 7 of 9 on the bottom and of 22 on top. getting the bottom in for the first time yesterday took about 10 mins before they snapped into place. last night before bed? took 20 mins...i gave up halfway and had a damn beer. finally got them in. today i figured out that they have to go over a different tooth first and not a molar as in the past. so...if you have trouble just try to get them in over a different tooth first. i hope this wont happen up top. ive got 3 crowns on the right id really like to not lose, lol..
fabfemme
#2 Post by fabfemme »
make sure to tell yr dr! they need to know when/if they don't start fitting as well.
best!
avl
#3 Post by avl »
thanks! everything is cool now. i can get them both, upper and lower, in and out in under 30 sec but they feel "normal " as in, like they should, while they are in.
i was really close to calling them about the fit but i think it was as it was supposed to be. including this tray i have 3 more till the bottom is done. at that point ill be just about halfway for the uppers.
