Please help!!! tooth shifting...Please reply
I wear my retainers every night, had my braces off over a year ago...my wired one on the bottom and usually the essex, sometimes vice versa..the one front bottom tooth is turning a bit..can the wire retainer be tightened to move it back into place??? I am so upset....please reply!!
Sasha
Top ceramics on 10/14/04
I just went in Thursday for a retainer check and one of my top front eye teeth is starting to rotate back to it's original problem, too, even with dilegent retainer wear. My ortho made some adjustments to my retainer (it is alot tighter!) and put alittle bend in the wire where that tooth is to try and push it back. I think it is already starting to get alittle better. I have to go back in 8 weeks to see if this is correcting the problem. So, yes, go in and see your ortho.
Becky
Becky
Just be aware that when you go to an "active" retainer, in other words you want to move a tooth, like with a bend or spring, then you will most likely have to wear the retainer 24/7 for a while until the tooth is settled in the bone, because wearing it only at night will cause it to move back during the day. Been there.
Top Braces June 2004
Bottom Braces November 2004
Debanded January 2007
I wish I knew the answer to that one, I figure 3-6 months, but thats a guess. You'll have to ask your ortho that one. If you leave the retainer out for half a day and see that its moved again, you'll know its not "set".Chris....what's the amount of time it takes for a tooth to settle into the bone after being moved with a retainer?
I just recently got the wrap around Hawleys (top and bottom..boy is it a mouthful!) and it closed my gaps up overnight but she said I only had to wear them for 3 months..I just worry that is not nearly long enough! I do have the bonded top and bottom retainers as well but I had gaps in a few teeth that weren't in the bonded retainer until I got these Hawleys. I guess I still struggle with my ortho's philosophy that I only need to have the bonded ones and that the rest will stay in tact after 3 months.
full metal braces 4/26/05~~debanded 12/13/07!
12/13/07 bonded retainers + wrap around hawley
