I've just had my third molar out, I'm due to have a forth one out in two weeks.
The first two I had out are healing nicely but I'm finding chewing things virtually impossible because there are no teeth in the place I usually chew with!
If someone could give me some reassurance that this will get better I'd really appreciate it
Feeling sorry for myself :(
chewing
I had 4 molars taken out all at once (2 top, 2 bottom) so I know what you mean. I've learned that when I need to chew i either nibble with front teeth or push way back to where there is a molar...
The good part is that I eat more slowly, so I consume less. You get used to it....
I unexpectedly lost a molar during osseous surgery, and that was a bummer! It hurt pretty bad the first day, but after that it was fine. It was one of the molars I relied on for chewing though, so I had to start using the other side to chew. That took some adjustment.
I hope your recovery has gone well!
Click on WWW to see my braces story.
August 16, 2007 - Braced on top
January 3, 2008 - Braced on bottom
