Surgical Hooks
jojo30
Surgical Hooks
#1 Post by jojo30 »
Hello everyone have been viewing this site for the past two months. I had bsso op on 5th March . I found the recovery ok albeit being tightly banded for 2 weeks post op. Then looser elastics. It has all gone very well os and ortho very pleased my question is I have had the surgical hooks on since Feb 28th and following a meeting with orthodontist yesterday it will be another 3 weeks which will be almost 10 weeks in total. Is this the usual length of time?
Emaciated
#2 Post by Emaciated »
All of my hooks were removed at my first visit to the ortho after surgery. I think that was 2 or 3 weeks after I released from the hospital. I don't see why you would still need them unless they're planning on installing another splint at some point.
Rach
#3 Post by Rach »
I got my surgical hooks on January 25th for my surgery on January 28th, Ive still got mine and will do till I am debanded (June 6th). So no I think it varies depending on how you ortho does things. Hope that helps :D
Feel free to take a look at my SurgeryBlog
loulou123
#4 Post by loulou123 »
Im 10 weeks post surgery and had my bottom surgical hooks taken off nearly 2 weeks ago, but my upper surgical hooks are still there.
Think they just remove them when they need to replace the archwire, so i wouldnt worry to much.
dubnobass
#5 Post by dubnobass »
I had my lower hooks swapped out along with the lower archwire at 2 weeks post-op. I still have my upper surgical hooks on the steel wire that's been there since the surgery, almost 9 months ago!
Braced May 2005
Bimaxillary surgery Aug 2007
Debraced Jun 2008
jojo30
#6 Post by jojo30 »
Thanks for the replies .
