Wobbly Tooth!!!!
sonja
Wobbly Tooth!!!!
#1 Post by sonja »
hi. i decided to cut my power chain because my tooth moved way too much, you could almost see it moving, it actually moved around 5mm in a week and had become very sore.
it has always been a little tender since i had some teeth removed around it.
anyway its quite wobbly now and being night time i cant do much about it but i am really worried. i will be phoning my ortho first thing in the morning and hopefully i will be able to get in, however in the mean time i am worried about loosing it........ i dont know if i did the right thing cutting the power chain but at the time i felt i had too because it was pulling my tooth too fast, it moved about 2mm just today..
once i cut it, it has now moved back about 1mm...
does anyone know if i should be worried about this??
sonja
#2 Post by sonja »
i went in and they just fixed the power chain. apartently its normal..
Jamesyeats
#3 Post by Jamesyeats »
They have to get wobbly and loose so they can move, Sonja! Some teeth move faster than others, some people's teeth move faster than other people's - we are all different.
