Does anyone have any pictures of before and after treatment?
Ems
#1 Post by Ems »
Hi am getting my impression done on the 10th September and am just wondering has anyone got any pictures of there before/during and after invisalign treatment?
The problem i have with my teeth is that my second teeth in on the top are twised and was wondering has anyone had any treatment done like this also?
I look foward to receiving your replys. :D
anastasia
#2 Post by anastasia »
Hey!
I might have about the same problem as you, my second front-teeth/lateral incisors or whatever they're called are rotated but all the others are straight (and really close together!). But I'm afraid it will be a while until I can post after-pictures, I just got started!
I've googled like crazy to find a similar case (there are loads of before/after pics online), and this is the closest I have found: http://www.oc-j.com/sept02/Invisalign.htm
My treatment is 25 upper trays/2 weeks each btw.
