why is my front teeth touching my bottom bracket
knockuout7788
#1 Post by knockuout7788 »
is this normal...
Des
#2 Post by Des »
HI, I also find that my teeth do that! It's very annoying and hurts when I chew! I think it's to align your bite. The first week al my teeth met at strange angles, but seems like it's settled down a bit.
That's the only suggestion I can make... :roll:
UGHBRACES
#3 Post by UGHBRACES »
Its because you have an overbite. Your treatment will correct that though.
