Any Shout-Outs on a GOOD Floss to use?
HeyLookatMeLookatMe
#1 Post by HeyLookatMeLookatMe »
Hi !
This forum is Fa-Boo!
I just got my ceramic hardware installed a couple of days ago. Can anyone recommend a great performing floss?
I have power chains, some kind of clear, funky ligament thing for closing the extraction gaps.
Thanks SO much from the newbie :HugeGrin:
--Lauren Loves Power Chains
Full mouth of ceramics installed: 1/26/09
Sentence: 12-14 months
(Possible early release pending model oral hygiene and braces behavior)
TumbleDryLow
#2 Post by TumbleDryLow »
I see you posted this awhile ago, but if you are still looking, I use Oral-B Satin Floss. It's a flat tape-type floss (as opposed to a round fluffy floss). I like it b/c it does not shred. Plus it's fairly rigid so I can get it under the wires very easily and only need to use a floss threader for my very back molars.
bbsadmin
#3 Post by bbsadmin »
Most people in braces use something like Glide Threader Floss or SturdyFloss because they have built-in stiff ends. There is also SuperFloss and Thornton 3-in-1 Floss, which have a spongy thick part, good for large gaps and spaces. To use your own floss, you can buy the FlossFish tool or the BridgeAid floss threader needle, which both help you floss with braces. We sell all of it at www.DentaKit.com
Lana
#4 Post by Lana »
I love Superfloss, it really works great. I haven't had problems with it shredding and it's easy to thread through the braces. I tried to use regular floss with a threader and the floss would constantly slip out of the loop on the threader. Superfloss made flossing easier for me, so i would recommend trying it at least, if you haven't already.
Lana
browneyedgrl
#5 Post by browneyedgrl »
I second glide threader floss!!!
B
Abbey70
#6 Post by Abbey70 »
OralB Super Floss seems to be tops in my teeth so far. I hate those threaders that you have to finagle the floss around. I also got a floss pik ($7.99 at CVS in PA), and that does OK.
Brackets and archwire put on 1/26/09
Spacers 2/24/09
Bands & rewire 3/9/09
Schwe
#7 Post by Schwe »
Another vote for Superfloss. :) It's three things in one! Stiff end eliminates the need for a threader, thick/spongy half for larger spaces, regular floss for tighter spaces.
Faerydust
#8 Post by Faerydust »
Thirding the SuperFloss! For me it's way faster than using a floss threader.
My Braces Story:http://www.archwired.com/phpbb2/viewtopic.php?t=25137
4/23/08 - Upper 1st premolars & lower impacted wisdoms extracted
-Getting lowers rebraced Aug. 30th-
Certified Dental Assistant
amandajane
re:
#9 Post by amandajane »
The floss I use is minted wax Oral-B Satin Floss or just the minted wax regular floss.
my story:viewtopic.php?t=31380
marky
#10 Post by marky »
I really like SturdyFloss, which I got at DentaKit.com.
yj207
#11 Post by yj207 »
I just use the cheapest regular waxed dental floss for 89-99 cents. It works for me!
sapphirerose924
#12 Post by sapphirerose924 »
Glide threader floss is great! I was using the Sturdy Floss, but it took two pieces, minimum, for me to floss every time because my wire ties shredded it. I am very happy with the Glide. :pinkbraces:
Steph in Sac
#13 Post by Steph in Sac »
Definitely Glide!!! (Also sold at Costco...)
