New, new, new!
koffymasheen
New, new, new!
#1 Post by koffymasheen »
Hey everyone! I'm new to archwired, and to braces in general. I just got my first adjustment today! Anyhoo, for my first post here, I just have a simple question. I have a fairly large gap between my front two teeth, and today, during my adjustment, the ortho asst told me that for my next adjustment, I'll be getting a chain to close my gap. What exactly is a chain?
Thanks everyone! :]
socksy
#2 Post by socksy »
They probably meant a powerchain, which is a chain made of elastic ovals linked together. They stretch the powerchain across the fronts of your brackets and it helps to move things around. My orthodontist has used them to rotate some of my lowers and also to close gaps.
clear Radiance brackets top and bottom
blindboarder2008
Location: in a house that has 4 walls, with lots of rooms!!! in Canada!
#3 Post by blindboarder2008 »
Welcome to AW and congratz on taking the plunge to get braces.
this sounds like a power chain. socksy did a good job at explaining it. The only thing i will add is that there will probably be some discomfort after for at least the first few days (could last up to a week and 2 weeks, really depends on the person). You can pick different colors for your powerchains as well. Bst of luck at your next adjustment and getting the powerchain. Oh I should probably tell you it could feel a bit weird when they first put it on but don't worry it does get better!!!!!
Braced: March 19th 2008
SDFD TSchott
#4 Post by SDFD TSchott »
Adjustment Sept 14th, 2018
Braces off April 02, 2008
