Just a couple of problems I'm having, and hoping you have some helpful suggestions....
1. If you guys can't tell from the screen name, I work as a paramedic.. that being said, I'm having trouble trying to balance the eating, doing paperwork, and brushing with a completely unpredictable job. It seems like I either have to leave them in for the entire twelve hour shift, or I end up taking them out and they never get put back in at work because I get a call... any suggestions would be great!!
2. I had attachments put on yesterday... two of the four have fallen off. I called my dentist and she wasn't concerned?!
Also, I was supposed to have two put on the bottom, but the aligner wouldn't fit with the attachments. Is this a problem with the attachment placement or my teeth movement? ( I am currently wearing the retainer without the attachments, and it fits just fine over my teeth).
3. I'm still feeling super hungry all the time... I'm a petite person, and used to grazing constantly... how long will it take before I get used to not snacking??
Thanks for all the advice!!
