pain -- but in between adjustments?
so i am 6 weeks into getting my bottom braces, and today i feel really tender around certain teeth. is this normal?? i thought this pain left after the first few days. do you get random bouts of tenderness in between adjustments that come and go?
Totally normal. On my last adjustment he took off my powerchain and repositioned a bracket. Because they couldn't get the same thick wire back into the repositioned bracket, he stepped down to a smaller one and decided to leave off the pc to give my tooth a chance to stand up a bit more. There was no pain until two days before my next adjustment. This time, on the other hand, he put on a pc that is a lot stronger than the other, and I'm on day 3 and its still hurting quite a bit. Either way, its totally normal and I still don't regret doing this at all.
Totally normal!
Earlier in my treatment when my teeth were still pretty wonky, random teeth would suddenly start hurting weeks after an adjustment.
I think it was a case of surrounding teeth having moved to a point where that tooth could start moving, hence the sudden pain!
It's all a sign of progress
Kitty
Kitty
