Is it normal to have elastics so early?
I've had my top braces on for a little over a month. At my next adjustment I will get my lowers...in addition to elastics.
I thought elastics was used toward the end of your treatment.
Elastics so soon?
Elastics so soon?
Uppers: August 13th, 2009 (no spacers)
Lowers: October 13th, 2009 (following one extraction October 9th, 2009) with elastics
Sentence:18-24 months
Hoping for an early release (good behavior)
![Image](http://tickers.TickerFactory.com/ezt/d/4;10711;116/st/20090813/e/Brace+day/k/ffb4/event.png)
- BRACEYOURSELF!
Some of that depends on the type of braces.
For example if you are being treated with Tip-Edge brackets you start with elastics on day 1. With straight wire brackets elastics are often used more at teh end but for certain situations can also be used early.
Developer of:
http://sixmonthbraces.com/
