Expander (RPE) - How long????
I had a RPE (expander) put in when I got my braces. I'm somewhat getting used to it but still not talking like my old self. I was just wondering who else has has had one and how long do you typically have to wear it?
August 17, 2009 - Upper spacers
August 24, 2009 - Lower spacers
August 31, 2009 - Ceramic upper and metal lower braces AND RPE (lucky me!)
Estimated treatment - 30 months
http://sarahintxbracesjournal.blogspot.com/
It sounds like you are not getting a surgical expansion, is that right? There have been other people on the board who expanded non-surgically, maybe you can find more details about their cases if you look around. How much expansion do you need?
http://www.archwired.com/phpbb2/viewtopic.php?t=30610
RPE 7/30/09 SARPE surgery 7/31/09
expansion 8/7/09-8/24/09
You are correct, this is a non surgical expansion. Thank goodness. I don't recall my ortho telling me how far my molars would have to move. If I had to guess I would probably say about half a cm on each side though.
I have a palatal expander in now, non-surgical, it was put in on the 16th of June. I was done turning it on the the 16th of July. I have a Hyrax with buccal bars. At my last Ortho appt, I though it was coming out, but they just ground off the buccal bars. I hope at my next appt, this Thurs, it comes out. You'll never be able to say Sally sells seashells by the seashore without sounding like a moron, but it does get pretty good over time. My son, 7, had one placed a month before mine and had it removed last week! So' I'm a little jealous of him. I really think it depends on the Ortho, severity of you specific case, how far into you braces treatment you are ect. I'll follow up if I get this evil device out of my mouth! GOOD LUCK!
JOHN
JOHN
i had mine on for about 3 months. I was originally told 6 months so it was quite a surprise when my ortho told me to make an appointment to remove it. Mine was non- surgical expansion and i was told to turn it 30 times, once every other day. I did stop a few turns short of that as i noticed my molars starting tipping. Overall, it did do its job. I took me about 5 weeks to get totally comfortable talking with it. The only word i had trouble with after that was the name of the company i work for.
You give me something to look forward to Junkee...I guess I'll cross my fingers and wait for the day when the ortho tells me it's time to take mine out. I'm turning mine every other day as well, beginning on August 31st.
In phase 2 treatment, we like to keep the RPE in until we get a rectangular stainless steel archwire in the brackets. We tend to expand this somewhat to make sure there is something to help maintain the expansion.
The general consensus is that we want to allow bone to form within the expanded suture before removal as this is what keep the desired expansion after brackets are removed.
Dr. Jason Tam
http://www.mcosmiles.com
I had an expander (non-surgical) for 4 months (Feb-June). I only turned it once a day for 2 weeks. I think my ortho is pretty conservative when it comes to non-surgical expansion, not wanting to expand too much and tip the molars. I'm not looking for a super wide arch, just enough so that all my teeth fit nicely aligned.
My Journey with Braces: http://bracingit.blogspot.com/
(updated: 11/9/10)
1/15/09: Lower Braces, Upper 4 brackets
1/27/09: Upper Palate Expander
2/25/09: 3 Teeth Extracted
6/22/09: EXPANDER WAS REMOVED!!!! =]
11/9/10: Cross Elastic Started
10/19/11: Next Adjustment
(updated: 11/9/10)
