![Smile :-)](./images/smilies/icon_smile.gif)
Brown stains around brackets
Hello - i've had my braces on for about 6 weeks now. I have been keeping them and my teeth really clean as i was worried about decacification (the white spots you can get on your teeth around brackets). However i have now noticed brown stains on my teeth around my brackets - it looks like the stains i used to have on the inside of my bottom teeth before i had a good scale and polish and i think it was the result of too many cups of tea over the years
So my question is, how can i remove the stains with my braces on?- at this rate i will have brown teeth when my braces come off - will the ortho give them a proper clean when i go in for my adjustment in 4 weeks before he changes the wire? Will s normal dentist be able to de-stain them whilst the brace is still on? Should i be using smokers toothpaste or something? How do i get behind the wires to remove these stains?
Good question..I'm starting to notice the same thing. I drink a lot of tea! I was thinking that it was the glue from the bracket that's becoming stained..usually after a good brushing it's gone but I've only had these brace for 2 months. I'm wondering if it will get worse as time goes by and what can I do besides giving up tea ![Confused :?](./images/smilies/icon_confused.gif)
![Image](http://tickers.TickerFactory.com/ezt/d/4;31;95/st/20090908/e/getting+braces%21/k/88f8/event.png)
![Image](http://tickers.TickerFactory.com/ezt/d/4;10714;106/st/20101221/e/10th+adjustment/k/fa8b/event.png)
Not sure if this will help completely, but I use an electronic toothbrush that has a super small tip as one of the attachments. Probably a centimeter long and a couple millimeters wide. It's perfect for getting behind the wire in those spaces I can't get my regular toothbrush to reach as easily as I want.
Upper: Damon3mx on 6/1/2009
Lower: 7/27/09
4 extractions done in May
Canine exposure eventually
Lower: 7/27/09
I'm a coffee drinker and the glue around some brackets has stained. It gets worse the longer I have braces. The staining on the glue does not go away with dental cleaning by hygienist (might get a bit lighter). I mostly use a straw now for coffee.
![Image](http://tickers.TickerFactory.com/ezt/d/4;10718;121/st/20100608/e/Braces+Off/dt/-3/k/e323/event.png)
Braced for 2 years, 11 months, 2 weeks and 5 days (the 2nd time ‘round)
Hawley on top, Essix on bottom
An update on this one - i had to go to my Orthodontist as my wire came away from my back tooth and so i asked about the staining. He said it was the glue from when the brackets were fixed on and he would clean it all off at the next adjustment & it wld not be a permanent stain and said my teeth were being well looked after etc and no sign of cavities etc (which is what i was worried about) . So hopefully thats all ok then! Oh and also i got my next wire on early as my teeth are moving well. Teeth feel tight again and i'm going through tender teeth when chewing again but happy to be 4 weeks ahead in my treatment ![Smile :-)](./images/smilies/icon_smile.gif)
I get stains as well but not in the glue, on the teeth -somehow it seems that smoking, cofee and wine stain teeth more with braces than before. I've had a couple of cleanings and everthing goes awa, so don't panic! ![Very Happy :D](./images/smilies/icon_biggrin.gif)
braced 07/02/08, braces off january 2010
sentence: 18 months, upper and lower damons + elastics
Bonded+essix retainers
My story: http://www.archwired.com/phpbb2/viewtopic.php?t=28298
![Image](http://tickers.TickerFactory.com/ezt/d/4;14;3/st/20080702/e/Braced/dt/6/k/7a70/event.png)
Yeah I get way worse coffee stains on the teeth too, since I got braces. However those clean up completely with professional cleanings. The excess glue stains, not so much. My self ligating ceramic braces do not stain, but the glue around them does ![Sad :(](./images/smilies/icon_sad.gif)
Re: Brown stains around brackets
I think the tech who prepared my teeth for the bracket placement glued practically my whole tooth. Is that normal?! I don't want it to all stain!!
![Crying or Very sad :cry:](./images/smilies/icon_cry.gif)
![Rolling Eyes :roll:](./images/smilies/icon_rolleyes.gif)
![Shocked :shock:](./images/smilies/icon_eek.gif)
No, I only have glue under the bracket. My ortho scrapped all excess glue off. Ask them to scrap it off.
I developed heavy staining around my brackets soon after bracing; turned out to be the Cetyl Pyrindium Chloride in the ACT fluoride rinse I was using. The staining was removed, I stopped using the stuff, and was fine thereafter.
Hi,
So i am assuming that several coffee in a day is not an issue while you are wearing braces.. Am i right? as i am too addicted of coffee and can't leave it :(
I have metal braces and the light reflects differently with all the metal. I have slight staining and I'm having a deep cleanse on Monday (brackets been on for 9 weeks). Tea and coffee to tend to stain all teeth with braces or not. I use a non-alcohol fluoride mouth wash. I have heard some can discolour teeth. I'm sure when the braces finally come off and after a thorough clean and polish all will be great
Sameerali, I drank black coffee almost every single day while I had braces and did not have a problem at all. I had the ortho scrape off any excess glue and I avoided Cetyl Pyrindium Chloride mouthwashes (after learning the hard way), and I was totally fine. Drink your coffee in peace!sameerali wrote:Hi,
![Mr. Green :mrgreen:](./images/smilies/icon_mrgreen.gif)
SARPE: December 19, 2013
TPA out: December 17, 2015 (due to issues)
My blog
My blog
Thanks Jaime.. Could you please tell me why you are not using Chloride mouthwashes ? are there any disadvantages?
Yup, because they have a tendency to stain your teeth to a dingy brown colour. It's difficult to remove it at home, but it can be removed by a routine cleaning at the dentist.sameerali wrote:Thanks Jaime.. Could you please tell me why you are not using Chloride mouthwashes ? are there any disadvantages?
My blog
My blog
