Hi everyone, so I have been debraced for about a month now and I dropped my hawley on the floor. It seems that I bent the wire and it's pressing against my front right incisor. My ortho is closed on the weekends so I'm not sure what I should do.
If I leave the retainer out until Monday, my teeth might shift. If I wear it and it needs to be adjusted, my teeth might shift. Should I wear my retainer or not.
Any advice would be greatly appreciated. Thanks
Hawley help!!
Hawley help!!
- freysmiles
Re: Hawley help!!
Given the date of the post, it looks like you got this resolved. I would leave the Hawley out. An active force on your teeth pushing it in a direction that might be bad will create more problems than you teeth moving on their own.
