The treatment will be ceramic uppers and metal lowers, a little IDS to avoid the black triangles on the upper incisors and possibly slight widening of the bite if the IDS doesn't create enough space for the teeth.
It's only the first week with them on and apart from the pain when trying to chew anything, they have been fine. I actually quite like the feeling of pressure on the teeth, knowing that they are being moved back into alignment. In fact, I can't wait for the lowers to go on. If I'm lucky the front incisors will have moved forwards enough to give space for the metal brackets on the lower teeth.
Day 0 - Fitting day
You can see all that crowding and staining
Day 9
I can't see much progress.
Oh well, I'm sure they are moving a little as I can feel a bit of extra wire appearing at the back of the braces.
