Time between next wire
KatrinkaNoir
#1 Post by KatrinkaNoir »
I just got my top braces yesterday and when they made my next appointment, they made it for eight weeks from now. My husband had braces as an adult and said the appointment should be in four weeks. Is this normal at first?
kennyandrew85
Re: Time between next wire
#2 Post by kennyandrew85 »
It's different for everyone.
I've had some 8 weeks, some 6, and even some 4...
Maybe your husband should do the rest as he's an orthodontist ? :)
Brace Date: 14th April 2011
starfish88
#3 Post by starfish88 »
4 weeks is more common with traditional braces as the ligs need changing. I'm on 8 week appointments with my SL brackets. It all depends on what needs to be done and my ortho doesn't always change the wire if it still needs to do more work so i may have the same wire for several months! I think appointments get closer together at the end too when all the little details are fixed.
16 months 1 week and 2 days in braces
12mm overjet and narrow jaws all fixed with braces and elastics.
http://www.archwired.com/phpbb2/viewtop ... =9&t=42441
KatrinkaNoir
#4 Post by KatrinkaNoir »
Oh, well that makes sense! I do have self-ligating on the tops, and I believe my husband had ligating all around. Makes perfect sense. It's funny what makes can make a person nervous at first. Eventually, I'll have this down pat and it will be so normal :). Thank you both for your help!
JillD
#5 Post by JillD »
Ten weeks for me. My H said the same thing as your husband did.
skinky
#6 Post by skinky »
There is so much to learn and keep straight! I thought it was every 4 weeks!
flips712
#7 Post by flips712 »
I just got braces and my first follow up appointment is in 8 weeks.
kiwibug
#8 Post by kiwibug »
6-8 weeks for me
TMJJill
#9 Post by TMJJill »
It is common to have the longer time between visits when you have the self-ligating braces.
Removal of Braces: September 18, 2013
TMJD treatment now complete!
Tobilei
#10 Post by Tobilei »
Mine vary. First one was about 7 weeks I think, then 4 and my next one will have been 6 weeks in between.
Ciara
#11 Post by Ciara »
Mine have all been from 3 to 5 weeks.
