Has anyone used this system? I am mid-fifties, had braces at 30 years old, lost the retainer years ago. There is some slight overlap of my two front teeth, slight rotation of side teeth upper and lower, and some slanting of bottom teeth. The ortho consult was that the red, white, and blue system of three retainers would correct/improve the situation. Full upper and lower braces would do more improvement, but the result should be acceptable with the RWB system. The cost is about $2700 less with the retainer system vs ceramic braces. This is a total of three retainers, not 18+ like with the Invisalign system. Any comments or opinions?
Thanks in advance.
Red, white, and blue retainer system
they work --OK.
Will do minor stuff, but dont expect major stuff to occur
Developer of:
http://sixmonthbraces.com/
In case any fellow readers also don't know what red, white, and blue is I googled it:
http://www.aoalab.com/
