* there is a size difference between the jaws
*the top teeth protrude 12mm (the average is 2mm) and the bite is deep
*the upper and lower teeth are mildly crowded.The upper right lateral incisor (adjacent to the front tooth) is missing.The upper right baby canine tooth is retained and is situated behind the upper right adult canine.Theupper right central incisor is darker than the other teeth.This tooth responds to an electric pulp test but less so than the upper left central incisor.This suggests the tooth may be dying and if so will require a root canal in the future.
Treatment :
* a limited treatment to reduce the protrusion of the upper teeth as much as possible.To achieve this you will need to have 2 teeth removed (upper right baby canine and upper left first premolar) and upper & lower braces fitted. two orthodontic mini screws may be needed to help control the tooth movements. The space on the upper right would be closed leaving the upper right canine next to the central incisor.although im confident a considerable improvement can be achieved,full correction may not be possible.
does this sound like a decent alternative plan? I really don't like the idea of having teeth removed as i have read that 'extraction and retraction' techniques can make the profile look worse ( i really hate the shape of my face already,i have a very small chin with hardly any definition) and that it can lead to problems such as sleep apnea
please give some advice on what you would do in my situation. thanks - Mel
