Dental implant in place of extracted wisdom tooth
If you are planning to get dental or facial implants as part of your orthodontic treatment (or if you already have implants) you can discuss them on this forum.
vhs81
#1 Post by vhs81 »
Has anyone had a dental implant in place of extracted wisdom tooth? My face collapsed on the left side after the lower wisdom tooth on that side was extracted 2 years ago. Your input is deeply appreciated.
Thanks.
BracesU
Re: Dental implant in place of extracted wisdom tooth
#2 Post by BracesU »
I see no one has responded to your question and there are no updates. Did you ever decide on an implant? What have you found out?
metalliKa
#3 Post by metalliKa »
Evidently, there wasn't room to compensate the wisdom teeth so hence the extraction.
Sentence: 12-15 months
Jailed: 3/24/15
Released: 5/24/16
FixMyTeeth
#4 Post by FixMyTeeth »
How would extracting a third molar cause the face to "collapse"?
Woohoo068
#5 Post by Woohoo068 »
The bite will collapse yes I have that too replace it as fast as you and don't get teeth removed it's unnecessary find an non extraction orthodontist they do exist
leonabritt
#6 Post by leonabritt »
Did you get dental implants in place of wisdom teeth? Do you find any difficulty with the procedure? I have heard it would be difficult to treat since you left it without any treatment for 2 years.
