Ticker Factory
musicbrace
Ticker Factory
#1 Post by musicbrace »
Could someone help me use this?
I can't find the braces ticker.
metalliKa
Re: Ticker Factory
#2 Post by metalliKa »
You have to go to http://www.tickerfactory.com/ezticker/t ... signer.php and enter all your information there then you'll get a link to copy and paste to AW.
Oh, sorry! There is no braces ticker. I used the "event" ticker.
Sentence: 12-15 months
Jailed: 3/24/15
Released: 5/24/16
desianne33
Re: Ticker Factory
#3 Post by desianne33 »
I just tried it.....not sure if it worked.
desianne33
Re: Ticker Factory
#4 Post by desianne33 »
No it didn't. now do you attach the ticker? In your signature on your profile?
metalliKa
Re: Ticker Factory
#5 Post by metalliKa »
When you get to the end then you'll get a link, copy that, then in AW go to your user profile and then edit signature and paste the link there. I believe the link has to go in between the img thingy. That's how I did it.
Jailed: 3/24/15
Released: 5/24/16
metalliKa
Re: Ticker Factory
#6 Post by metalliKa »
Sorry, not used profile but user control panel, then profile tab then edit signature.
Jailed: 3/24/15
Released: 5/24/16
musicbrace
Re: Ticker Factory
#7 Post by musicbrace »
Thank you!
