As you can tell from my username, I consider my midface to be in the longer side.
I'm soon going to get braces and a palate expander. While I am not certain if I have any significant bite problems and in fact neither do I have a gummy smile, excessive incisor show at rest nor do I have a long philtrum , I'm quite bothered by the appearance of my elongated face. I'm certain it isn't the only facial trait thing that is "bringing me down" but I strongly feel that it's something that if I was able to correct, it would make a significant difference to my facial harmony.
Here's a picture of my current face :
http://i.imgur.com/YN6fCjO.jpg
I've read about the LeFort I maxillary impaction that theoretically helps shorten a long midface and correct a gummy smile, but I've also read that the length of the midface doesn't get noticeably shorter. I'd appreciate it if a fellow member here who has had impaction can tell us about their experience.
To put it simply, I want to know if it's possible for me to surgically achieve a compact midface, a middle third length similar to the guy's below :
http://hairstyles.thehairstyler.com/hai ... -Zylka.jpg
Another question which is more general is how many millimeters of impaction can make a significant change in the length of the midface. Would 2 or 3 millimeters be enough in a case of, let's say, not excessively gummy smile?
Thank you for your time and pardon me if this post got a little longer than you expected !
