My storage solution.
Amysown1
#1 Post by Amysown1 »
I want to include a picture, but I don't think I have permission yet to post pics. However, I wanted to share my portable storage solution that I love. It seals water tight so won't leak in your bag. I also have an insulated lunch bag to keep them from warping in the heat of the car. I never let my aligners dry out so I always rinse and then soak them in my little box whenever I remove them. 50%peroxide/50%water if I'm home or just water if I'm on the go. The box is made by Sistema and it's a cube shape, 13.5oz/400ml. It is BPA free.
PinkPeep
Re: My storage solution.
#2 Post by PinkPeep »
Hi!
That is a great idea you have to prevent warping in the car! I also use peroxide and water to soak my aligners. I find it works well and they stay very clear. It is unfortunate that this forum does not seem to have much traffic. Good luck with your journey!
