loose tooth
lheilner59
loose tooth
#1 Post by lheilner59 »
has anyone else noticed a tooth that feels somewhat loose? I am three months in and upper left hand side has one tooth that feels like it moves when I bite on it.
wendydong
Re: loose tooth
#2 Post by wendydong »
i would say go to your ortho or dentist and get an xray taken on that loose tooth
kplatt2010
Re: loose tooth
#3 Post by kplatt2010 »
Hi There- I know in the beginning of treatment, I noticed a curve in my archwire and thought I had done it. I tried pushing around the area and literally pushed one of the teeth back out of alignment. That took a few months to fix LOL!! However; since the jaw surgery, I am having challenges with getting teeth to move. Image
jwbraces
Re: loose tooth
#4 Post by jwbraces »
My ortho told me that I might feel like teeth are loose at times, and that is normal. Right now I have some that seem to move a little (like pop into and out of place). I believe it to be normal. I would only be concerned if it was super loose feeling. It still wouldn't hurt to give your ortho a call if you are still concerned.
Speck
Re: loose tooth
#5 Post by Speck »
I agree with jw. I've got at least two teeth, each with a slight wiggle right now and a Bugs Bunny incisor being one of them.
-Andy
assertives
Re: loose tooth
#6 Post by assertives »
It is quite normal to feel some teeth a little more loose than the others. I have a couple of such teeth now and I'm about a year and 2 months into treatment.
