Finishing phase time????
I’m curious as to approximate times for “finishing” stage where fine adjustments etc. are made. I have read that the initial alignment phase generally moves fairly quickly around 6-7 months. The second phase or “bite alignment” I believe typically takes the most amount of time. Does anyone have any info on the finishing phase? I know everyone is different and each case is individual, but I am interested in what others have heard!!! My ortho has talked about putting something slight bends in wires to move teeth into a final alignment. Thoughts?????
Re: Finishing phase time????
I was in finishing wires for the last 13 months of my treatment. My orthodontist made small adjustments to align my teeth and worked on my bite during those months.
Braced: April 07, 2017
Debraced: February 08, 2019
Sentence: 18-24 months
Actual time in braces: 22 months and 1 day
Reason: Straighten teeth, correct crossbite and edge-to-edge bite
http://myjourneyandlifewithbraces.blogspot.ca
My ortho told me that the finishing phase usually takes about 6 months to complete.
My finishing phase (which is nearly finished) has taken the longest and has been the slowest part, its been a pain getting tiny movements over a couple months!
i spent about 6 months in active retention, iirc after a few adjustments and getting my entire uppers repositioned. For finishing, they did my IPR early on.
My finishing is annoying. They should have removed my molar rings up top a few visits before to let those come forward instead i have had to use minor tooth movement via adjustments in essex aligners.
2 months
2 months
